EME contest
EME contest
Сообщение EW1AA »
ARRL EME contest
Contest Details
1. Object: Two-way communications via the earth-moon-earth path on any authorized amateur frequency above 50 MHz.
2. Date and Contest Period: Three full weekend 48-hour periods (0000 UTC on Saturday through 2359 UTC Sunday). 2017 dates and designated bands:
September 9-10: 2.3+ GHz
October 7-8: 50-1296 MHz
November 4-5: 50-1296 MHz
3. Entry Categories:
3.1. Single Operator All Mode: Any combination of CW, phone, or digital modes. Available for all bands.
3.2. Single Operator CW Only: 144, 432, and 1296 MHz bands and Multi band logs.
3.3. Multioperator All Mode: Any combination of CW, phone, or digital modes. Available for all bands.
3.4. Multioperator CW Only: 144, 432, and 1296 MHz bands and Multi band logs.
4. Exchange: Each station must send and receive both call signs and a signal report in any mutually understood format, plus an acknowledgment of the calls and report. Partial or incomplete contacts should be indicated on your log, but not counted for contest credit.
5. Scoring:
5.1. QSO points: Count 100 points for each complete EME contact.
5.2. Multiplier: Each US State and Canadian Province, plus each DXCC entity (excluding the US/Canada) worked via EME on each band.
5.3. Final Score: Multiply QSO point total by the sum of multipliers worked from each band.
Miscellaneous:
6.1. A Multioperator entry may be made up of neighboring amateurs within one state, province, or non-US/Canadian DXCC entity, but with EME facilities for different bands on different team members' premises, as long as no two are more than 50 km (30 miles) apart. Multioperator neighborhood groups may use the same call signs at each location if permissible under national licensing rules and regulations. If not permissible, separate callsigns may be used for the multioperator neighborhood entry. When operating under this neighborhood provision, all logs must be submitted together in a single envelope or email with a single summary sheet showing the combined operation, designating the principal callsign for the entry. All multioperator callsigns will be shown in the results.
6.2. Stations may be worked for credit only once per band, regardless of mode.
6.3. All entrants, regardless of category, are permitted to use spotting assistance or nets including but not limited to DX-alerting nets, internet chat rooms, APRS and other packet, reverse beacon networks and repeaters to identify stations available for contacts and to announce (self-spot) their availability for contacts. Announcements shall be limited to call sign, location, band or frequency, mode and–if applicable–transmitting sequence and listening direction. These methods of spotting assistance may also be used to coordinate antenna peaking prior to initiation of the contact and to explain contest rules, such as the exchange required, for those who need clarification. Such assistance may not be used to facilitate the completion of any contact once the contact has commenced. This means such assistance may not be used to convey receipt or non-receipt of any required element of a contact or to request a repeat of any required element of a contact.
6.4. Only one transmitted signal is allowed per band at any given time; alternating CQs on two or more frequencies using the same band and mode is prohibited.
6.5. There is no specified minimum terrestrial distance for contacts, but all communications must be copied over the EME path, regardless how strong (or weak) a nearby station's terrestrial signal may be.
6.6. Commercial Equipment: Stations using equipment that is not amateur-owned (such as a dish antenna or lab equipment owned by an institution or government agency) are ineligible for awards.
7. Reporting: Entries must include complete log data as well as an official ARRL EME Contest Summary Sheet. Official forms are available at the top of this page under "Overview: Paper Entry Forms" or with a SASE request to the Contest Branch. No other forms of the summary sheet will be accepted. Each line of QSO data in the log should contain band, mode, date and time in UTC, callsign of station worked, exchange sent, exchange received, each new multiplier, and points earned. Photocopies of the log form and official Summary Sheet are acceptable. Logs should be emailed to EMEcontest@arrl.org and hand-written paper logs mailed to: EME Contest, ARRL, 225 Main St, Newington, CT 06111 USA. Log Submission Deadline - All entries must be emailed or postmarked within 30 days after the event - no later than December 5, 2017.
8. Awards: Certificates will be awarded to the top three stations worldwide in each of the following categories where significant effort or competition is evident. Multiband entrants will also be listed in the single band tables, and are eligible for those awards.
8.1. Single operator, Multi-band, All Mode
8.2. Single operator, Multi-band, CW Only
8.3. Single operator, All Mode, for each single band.
8.4. Single operator, CW, for each of the single bands 144, 432, and 1296 MHz.
8.5. Multioperator, Multi-band, All Mode
8.6. Multioperator, Multi-band, CW Only
8.7. Multioperator, All Mode, for each single band.
8.8. Multioperator, CW, for each of the single bands 144, 432, and 1296 MHz.
9. Other:
9.1. See “General Rules for All ARRL Contests” and “General Rules for ARRL Contests on bands above 50 MHz (VHF)."
Последний раз редактировалось EW1AA 13 сен 2017 14:55, всего редактировалось 1 раз.
ex RC2AA, UC2ABT
Re: ARRL EME contest
Сообщение EW1AA »
Разместил положение о тесте для тех, кто интересуется ЕМЕ.
Если будут вопросы по положению, или составлению отчетов,
пишите здесь.
Сергей
ex RC2AA, UC2ABT
Re: EME contest
Сообщение EW1AA »
В эту субботу и воскресенье осенний тур итальянского ЕМЕ contest-а.
Все диапазоны, все виды излучения, включая цифровые.
A.R.I. Italian EME Trophy – 2017
Autumn Session: from 00.00 UTC of September 16th to 24.00 UTC of September 17th 2017
Bands: 144 MHz – 432 MHz - 1.2 GHz - 2.3 GHz - 5.7 GHz - 10 GHz - Separate classification for each band.
Если нужны уточнения (составление отчета и т.д.), пишите.
Сергей
ex RC2AA, UC2ABT
Re: EME contest
Сообщение EW1AA »
Прошел ARI EME contest.
Первый раз работал в этом тесте.
Работал только на 23 см.
Из-за дождя, прекратил работать до окончания теста.
Только 13 QSO. Одна новая страна (и новый корреспондент).
Очень слабая активность.
Сергей
ex RC2AA, UC2ABT
ex RC2AA, UC2ABT
Re: EME contest
Сообщение EW1AA »
Вот и закончился сезон ЕМЕ соревнований в 2017.
Сегодня прошел последний в этом году тур ARRL contest-a.
Работал на 23 и 13 см диапазонах, 28 QSO.
Сравниваю с прошлым годом.
Очки не считал ( ещё не «проснулся», две ночи без сна).
Количество связей, и множители на каждом диапазоне,
возросли в два раза. Результат, думаю, в четыре.
Сказалась модернизация аппаратуры.
Антенна увеличена с 1,2 до 1,5 м,
Облучатели (были линейными), заменены на septum (самодельные).
Мощность осталась прежней.
Принимал много корреспондентов, но они меня не принимали.
Слишком маленькая мощность, особенно на 13 см.
Кто ещё работал, или принимал в этом тесте
сигналы на 144 и 432 МГц?
Может EW7AW?
Надо активизировать этот вид связи.
А то мы находимся на уровне стран, в которые организуют DX- экспедиции.
Сергей
ex RC2AA, UC2ABT
Re: EME contest
Сообщение EW7T »
Да, это для вас Сергей Николаевич соревнования закончились :-( Я так понимаю ещё до 00UTC будут идти, и сейчас луна на восходе и можно её "бомбить" без элевации :-): Ну шумов хватает и желания нет заниматся "мазохизмом" в эфире. Работать, так работать - не "по-детски". У нас сейчас станций 5 могут провести связи в зачёт, и сказать больше - получить дипломы ARLL на почте! Так что вперёд кого может и это заинтересует! :co_ol:
Re: EME contest
Сообщение EW1AA »
EW7T писал(а):Ну шумов хватает и желания нет заниматся "мазохизмом" в эфире
Так наше хобби - это сплошной "мазохизм".
Не обязательно занимать первые места, можно работать и ради собственного удовольствия.
Я, например, соревнуюсь сам с собой, совершенствуя свою аппаратуру.
Да, согласен, на 144 и 432 в городе работать очень сложно.
Уже год, как снял антенны на эти диапазоны. На 144, кроме минчан, никого не слышу.
Непрерывная помеха 59+20 (минимум).
Появились современные китайские электровозы, которые «гадят» на порядок больше, чем советские.
А у меня по окнами не только 4 рельсовых линии, но ещё и железнодорожный тупик.
Короче, нервы не выдержали.
Чтобы не было помех, переходите на 1296 и выше.
Если сделать хорошую динамику МШУ (проблемы с базовыми станциями), работать можно.
Через Луну, на 23 см диапазоне, без проблем, работаю с 3м параболами +100Вт.
Нормально принимаю и 2,2м+200Вт, но моей энергетики не хватает для того,
что бы меня приняли.
На 13 см диапазоне, из-за моего QRPP, не всё так хорошо.
Минимальная антенна, с которой удалось сработать - 3,7м.
Думаю на 6 и 3 см, помех вообще не будет, но проблема с финансами для РА этих диапазонов.
Сергей
ex RC2AA, UC2ABT
