122ГГц
122ГГц
Новый мировой рекорд - 139 километров на 122ГГц
Fwd: [50MHzandUp] We did it! A new world record on 122 GHz
Кому: Vladimir Chepyzhenko <eu2aa@eu2aa.com>
Дата: 21.02.2020 21:16
---------- Forwarded message ---------
Date: Thu, Feb 20, 2020 at 5:50 PM
Subject: Re: [50MHzandUp] We did it! A new world record on 122 GHz
To: Mikhail Popov <mikhailp@pacbell.net>, 50mhzandup <50mhzandup@lists.altadena.net>, MIKE LAVELLE <miclevel@comcast.net>
Cc: sbms <sbms@ham-radio.com>
there is a brief summary in the monthly ARRL letter. don't know if it will make it through the reflector filters
A new world distance record of 139 kilometers (86.2 miles) is being claimed by radio amateurs in northern California. This tops the record
Mike Lavelle, K6ML.
of 114 kilometers set in 2005 by WA1ZMS and W4WWQ, according to the Distance Records on the ARRL website.
The February 17, 2020, contact was between Mike Lavelle, K6ML, on Mount Vaca (CM88WJ75ON) at 835 meters (2,739.5 feet) above sea level, and Oliver Barrett, KB6BA (at 1225 UTC), and Jim Moss, N9JIM (at 1250 UTC), who were both on Mount Umunhum (CM97BD18VJ) at 1,016 meters (3333.3 feet) above sea level.
Lavelle reports the dew point was -11 °C, the air temperature was 15 °C, the path loss was about 225 dB, and atmospheric loss was approximately 0.35 dB/kilometer.
"CW was used, 122 GHz signals were very weak (7 dB above the noise in 22 Hz; -13 in 2500 Hz equivalent) with [fading] down to the noise floor," Lavelle told ARRL. "Dishes were aligned on 24 GHz (71 dB above the noise) prior to [moving] to 122 GHz; we heard signals right away on 122 GHz." The stations employed 60-centimeter satellite TV dishes and ran "somewhat less than half a milliwatt" on 122 GHz, Lavelle said.
Robin
Fwd: [50MHzandUp] Мы сделали это! Новый мировой рекорд на 122 ГГц
Кому: Владимир Чепыженко <eu2aa@eu2aa.com>
---------- Пересланное сообщение ---------
От: Робин <wb6tza@socal.rr.com>
Дата: четверг, 20 февраля 2020 г., 17:50
Тема: Re: [50MHzandUp] Мы сделали это! Новый мировой рекорд на 122 ГГц
Кому: Михаилу Попову <mikhailp@pacbell.net>, 50mhzandup <50mhzandup@lists.altadena.net>, Майк Лавель <miclevel@comcast.net>
Копия: sbms <sbms@ham-radio.com>
в ежемесячном письме ARRL есть краткое резюме. не знаю, сможет ли он пройти через фильтры отражателя
Радиолюбители Северной Калифорнии заявляют о новом мировом рекорде в 139 километров (86,2 мили). Это вершина рекорда
Майк Лавель, K6ML.
114 километров, установленных в 2005 году WA1ZMS и W4WWQ, согласно данным рекордов расстояний на веб-сайте ARRL.
17 февраля 2020 года контакт был между Майком Лавеллом, K6ML, на горе Вака (CM88WJ75ON) на высоте 835 метров (2739,5 фута) над уровнем моря, и Оливером Барреттом, KB6BA (в 1225 UTC), и Джимом Моссом, N9JIM (в 1250 году). UTC), которые оба находились на горе Умунхум (CM97BD18VJ) на высоте 1 016 метров (3333,3 фута) над уровнем моря.
Lavelle сообщает, что точка росы была -11 ° C, температура воздуха составляла 15 ° C, потери на трассе составляли около 225 дБ, а атмосферные потери составляли приблизительно 0,35 дБ / километр.
«Использовали CW, сигналы 122 ГГц были очень слабыми (на 7 дБ выше уровня шума в [полосе] 22 Гц; минус 13dB в эквиваленте [полосе] 2500 Гц) с [затуханием] до минимального уровня шума», - сказал Лавелл ARRL. «Тарелки были сориентированы заранее на 24 ГГц (на 71 дБ выше уровня шума), до [перехода] на 122 ГГц; мы сразу услышали сигналы на 122 ГГц». Станции использовали 60-сантиметровые спутниковые телевизионные тарелки и мощность «чуть меньше, чем полмиллиаватта» на 122 ГГц, сказал Лавель.
Re: 122ГГц
На этой немецкой микросхеме: https://siliconradar.com/datasheets/Dat ... 2_V0.8.pdf
Схема, плата и описание есть в DUBUS 3/2019 стр.22-36
https://fundrazr.com/122GHzProject?ref= ... tXc93d6ziu
Плата на обычном FR4 - https://static.fundrazr.com/rewards/dab ... 2921840291
Рупорный облучатель - https://static.fundrazr.com/rewards/803 ... 2921980656
https://www.youtube.com/watch?v=GKfi10Mdc1g
Re: 122ГГц
