NEW BAND
NEW BAND
По сообщению DXNL 1768 (Feb 22, 2012)
New Band:
At the WRC-12 in Geneva ham radio representatives finally came to a
consensus on an allocation to the amateur service in the region of
500 kHz. 472 kHz through 479 kHz will become a new amateur band
as soon as the PTT administrations concerned have edited their rules.
The band is shared with Air Traffic Services which have priority.
Power mostly is limited to 1 Watt (EIRP).
А также WA6ITF:
RADIO LAW: WRC 2012 ENDS – THE OUTCOME FOR HAM RADIO
The 2012 World Radiocommunications Conference, better known as WRC 12 has come to a close. Bill Pasternak, WA6ITF, is in the Newsroom with some good news for ham radio:
At its Plenary meeting held on February 14th, the World Radiocommunication Conference approved a new secondary frequency allocation to the Amateur Radio Service from 472 to 479 kHz. Having passed its First and Second Readings it is normally a formality that this change be included in the conferences Final Acts when the gathering concludes and the Table of Frequency Allocations would then be amended accordingly.
As a secondary user, amateur radio shares 472 to 479 kHz with the Maritime Mobile Service which is the primary user in all three ITU Regions and with the Aeronautical Radionavigation Service which is a Secondary user except as noted in the following footnotes:
One footnote reads that a number of countries will identify their intent to elevate the status of their Aeronautical Radionavigation Service to Primary as a step in ensuring protection from secondary users.
Also there is a footnote that says that the power which radio amateurs may use in 472 to 479 kHz will be limited to 5 watts effective radiated except for amateur stations within 800 km of the borders of a number of countries. These are principally Russia, many of the former Soviet bloc nations and the Arab states. For those affected amateurs the power output limit will be 1 watt.
It is, of course, up to individual administrations to authorize use of the band by their amateurs. How long it will before the band is available to hams in the United States? That’s up to the bureaucrats in Washington D.C.. At this point that is unknown.
For the Amateur Radio Newsline, I’m Bill Pasternak, WA6ITF, in the Newsroom in Los Angeles.
73,Kazimir EW4MM
Re: NEW BAND
Сообщение vladem »
[quote="ew4mm"]По сообщению DXNL 1768 (Feb 22, 2012)
New Band:
I kogda na etom bande mozhno budet rabotat?
Re: NEW BAND
Сообщение EU7A »
vladem писал(а):I kogda na etom bande mozhno budet rabotat?
Пока стоит запасаться проволокой для антенны :D
А если серьезно, то это решение общее и пока не будет принято в отдельно взятых странах, то работать нельзя, как и на 6м сейчас - мир давно работает, а мы со своей восточной соседкой пока "облизываемся".
73, Андрей, EU7A
https://goo.gl/VuQ8NC
http://eu7a.esy.es/
Re: NEW BAND
:lol: :lol: :lol: А на всех остальных разрешенных мы уже работаем? ;)
Re: NEW BAND
Сообщение vladem »
Konechno! Vplot do 88HHz!
Re: NEW BAND
vladem писал:
Vplot do 88HHz!
Что за еденица измерения HHz?
Может перед тем как писать в рефлектор -просмотреть школьный учебник физики?!
Kazimir EW4MM
Последний раз редактировалось EW4M 22 фев 2012 05:53, всего редактировалось 1 раз.
Re: NEW BAND
Сообщение vladem »
ew4mm писал(а):vladem писал:
Vplot do 88HHz!
Kazimir EW4MM
Спасибо Казимир! Но слово единица пишется через И!
Re: NEW BAND
Сообщение eu4ag »
Vplot do 88HHz!
Kazimir EW4MM
1hHz=100Hz
88hHz(гектогерц)=8800Hz(герц)=8.8КHz(килогерц)=0,0088(мегагерц)
Т.е. аж до 34кm! Изображение
Re: NEW BAND
Сообщение EW1GR »
Окучиваю, бывало, DX-ов.... и тут бац! на третьем гектаре..... матерый такой DX-ище .....
8800Гц=0.0088Мгц
если что
-=Александр=-
Re: NEW BAND
Сообщение eu4ag »
Seldom писал(а): 8800Гц=0.0088Мгц
если что
Расчеты поправил Изображение Длина волны в 34 км - это круто Изображение
Re: NEW BAND
vladem писал:
Спасибо за исправление.К сожалению за 36 лет после окончания школы я больше забыл,чем Вы познали :oops:
Kazimir EW4MM
Re: NEW BAND
Сообщение vladem »
Kazimir EW4MM
Из всех ответов понятно, что надо копить деньги на антенну!
Re: NEW BAND
К сожалению ,только сейчас появилось время ответить.В связи с тем,что никто не последовал совету посмотреть в литературе информацию о еденицах измерения частоты-появились неточные коментарии в теме.Пришлось самому сесть за литературу.Когда речь идет о частотах радиочастотного диапазона начиная от звуковых частот -то обычно применяют: Hz ,kHz,MHz и GHz.
Приставки для кратных единиц.
Кратные единицы — единицы, которые в целое число раз превышают основную единицу измерения некоторой физической величины. Международная система единиц (СИ) рекомендует следующие десятичные приставки для обозначений кратных единиц:
Приставки для дольных единиц.
Дольные единицы, составляют определённую долю (часть) от установленной единицы измерения некоторой величины. Международная система единиц (СИ) рекомендует следующие приставки для обозначений дольных единиц:
Приставки следует писать слитно с наименованием единицы или, соответственно, с её обозначением.
Приставки, соответствующие показателям степени, не делящимся на 3 (гекто-, дека-, деци-, санти-), использовать не рекомендуется. Широко используются только сантиметр (являющийся основной единицей в системе СГС) и децибел, в меньшей степени — дециметр и гектопаскаль (в метеорологических сводках), а также гектар. В некоторых странах объём вина и других напитков измеряют декалитрами и гектолитрами.
P.S.
Обратите внимание,что только начиная с чисел величиной от десяти в шестой степени-приставки пишутся с большой буквы.
73,Kazimir EW4MM
Re: NEW BAND
Женева, 27 ноября 2015 года – Всемирная конференция радиосвязи 2015 года (ВКР-15) завершила свою работу подписанием делегатами Заключительных актов, пересматривающих Регламент радиосвязи – международный договор, регулирующий использование радиочастотного спектра и спутниковых орбит.
Более подробно на сайте ITU:
http://www.itu.int/net/pressoffice/pres ... /56-ru.pdf
Re: NEW BAND
Сообщение EU7A »
EW4MM писал(а):Женева, 27 ноября 2015 года – Всемирная конференция радиосвязи 2015 года...
Порадуемся за коллег из других стран. Наша администрация связи как раз против выдачи этого диапазона радиолюбителям по причине возможных помех другим службам. Теперь ждем окончательного решения по вопросу 6-ти метров.
73, Андрей, EU7A
http://eu7a.esy.es/
Re: NEW BAND
Сообщение EW2MS »
6-ти метровый диапазон ещё долго ждать :-): Раньше 2019г. не получим.
Re: NEW BAND
Нам не светит этот диапазон. В каждом гражданском и военном аэропорту до сих пор используются средневолновые NDB на дальнем и ближнем приводах. Например, в Барановичах дальние приводы с позывными ДЕ и ЧА на 477 кГц. Причём, частота плавает от температуры от 476.679 до 478.016.
Re: NEW BAND
Сообщение EU2Q »
может так справедливо будет
от 100 кгц до 30 мгц
нам отдать ?
Re: NEW BAND
To EU1KY:
Последние сутки обсуждалась информация с WRC-15 и ни слова не говорилось о диапазоне средних волн и еще появились поклонники р/хулиганства...
