3Y0Z Bouvet island
3Y0Z Bouvet island
Сообщение EU7A »
Наверное все знают, что в составе команды Нодир, EY8MM - отличный оператор, любитель ТОП бенда. Сегодня с ним обменялся несколькими словами - он сейчас в Чили и всё идет по плану. Вот такую картинку прислал, обратите внимание на флаг на дощечке с надписью по-русски :-):
73, Андрей, EU7A
Re: 3Y0Z Bouvet island
Процедура QSO в FT8 с 3Y0Z. Внимание: изменить макросы!!!
FT8
Ten Steps on How to Work 3YØZ (Bouvet) With FT8
Due to the relative newness of this mode, there is a need for operators to understand how to operate FT8 correctly and maximize their chances of getting into the 3YØZ log.
FT8 will not be a “primary” mode. We will use this mode when the band dies, or before it opens. If a band appears dead, watch for us on the FT8 transmit frequencies listed above. 3YØZ operations on FT8 will not use “normal” FT8 sequencing (read below). Using and understanding the following guidelines will maximize your success in making an FT8 (digital) contact with 3YØZ Bouvet.
1. First, your computer clock needs to be ACCURATE. Do not assume it is. An accurate time synch is mandatory for proper decoding and sequencing; http://www.makeuseof.com/tag/pc-times-m ... c-windows/ gives instructions on how to do this.
2. Download and install WSJT-X (Version 1.8.0-rc3 or newer) from http://physics.princeton.edu/pulsar/K1JT/wsjtx.html
3. Read the the FT8 Help files. ZL2IFB’s <Tips for FT8 DXers> is also extremely helpful.
4. We will NOT be using the normal FT8 band segments. To avoid QRMing normal FT8 activities, we will conduct our DXpedition FT8 activities just below the normal PSK segments (except on 6 meters). See our band plan above.
5. Do not transmit on our transmit frequency. Select a clear spot on the waterfall in the Wide Graph, do a <Shift, Left Click> on that clear spot to set your transmit frequency, and call us there. Check the box labeled “Hold Tx Freq” to keep your transmit frequency locked. We will not respond to callers on our transmit frequency.
6. Our transmit frequency may move around low in the passband, but that is OK. FT8 will decode the entire passband, and you will decode us wherever we transmit in that passband segment. Our moving around will also help deter DQRM.
7. FT8 is a low power, weak signal mode. High power and/or “heavy” audio processing will only hinder your ability to make a contact.
8. DO NOT SEND US GRID SQUARE INFORMATION. Before calling us, double click on the box next to the T1x message in the “Generate Std Msgs” window. This will toggle off the Tx1 message so that your calls to 3Y0Z automatically just include a signal report and the QSO sequence will be as indicated below. Remember DO NOT CALL US WITH A GRID SQUARE. We only want to exchange signal reports in order to maximize the number of QSO’s per hour. We will not respond to calls containing grid squares.
9. A typical exchange between KL7YL and 3YØZ will look like:
a.) Bouvet: K1ABC 3YØZ 73 (finishing a preceding contact)
b.) Vivien calls: 3YØZ KL7YL -06
c.) Bouvet answers with: KL7YL 3YØZ -02
d.) Vivien answers with: 3YØZ KL7YL RRR
e.) Bouvet answers: KL7YL 3YØZ 73
f.) The QSO is now complete and KL7YL is in the log. This took only one minute (four 15-second sequences) for a complete contact.
10. IMPORTANT!
If you see 3YØZ return to someone else, stop transmitting by clicking the “Halt Tx” button on the FT8 control panel. Continuing to transmit during a QSO will NOT increase your chances of making a contact. Immediately after seeing 3YØZ transmit a “73” to another station, click on the “Enable Tx” button to begin transmitting a signal report to 3YØZ.
Repeat until you are called by 3YØZ.
Сообщение EU7A »
EW4M писал(а): Внимание: изменить макросы!!!
А зачем? Все самые популярные сейчас софтины для работы в FT8 имеют необходимые макросы, описанные в инструкции выше. Надо только нажимать те кнопки, что надо.
А вообще это будет интересно посмотреть что будет происходить на диапазоне при работе ими в этой моде :-):
73, Андрей, EU7A
Не знаю. В отличие от некоторых на КВ принципиально в JT65 не работал.
FT8 начал осваивать только из-за экспедиции 3Y0.
Я в этой моде beginner и только за три дня до Нового года начал пробовать.
Из цифры предпочитаю классику- RTTY.
Сообщение EU1FQ »
EW4M писал(а):Процедура QSO в FT8 с 3Y0Z. Внимание: изменить макросы!!!
Основное отличие от обычного QSO в FT8 это то, что 3Y0Z будет отвечать только тем, кто сразу передает рапорт.
На ваш Grid ответа не будет!
Сообщение EW4C »
EU1FQ писал(а):Основное отличие от обычного QSO в FT8 это то, что 3Y0Z будет отвечать только тем, кто сразу передает рапорт. На ваш Grid ответа не будет!
Многие DX уже так и делают - не нужны им гриды :-):
73 ! de EW4C, Дмитрий.
Похоже, что с нынешним прохождением связаться с 3Y0Z на 12 и 10 метрах удастся исключительно на FT8. И шанс действительно есть, если стать на CQ даже на пустых диапазонах, развернувшись на юг, начинают подходить ZS, а пару недель назад даже VP8NO сам позвал, а он на той же широте, что и Буве. Их еле слышно, -22..- 24, но связи удаются.
Смущает, что они собираются пользоваться WSJT-X, который не умеет разгребать перекрывающиеся сигналы. Не декодирует ничего в таком случае. В этом плане JTDX намного лучше.
Сообщение EW6BN »
EU3EU писал(а):Смущает, что они собираются пользоваться WSJT-X, который не умеет разгребать перекрывающиеся сигналы. Не декодирует ничего в таком случае. В этом плане JTDX намного лучше.
Киловатты решают всё, буду давиться мощностью.
Кстати, раз они так радеют за QSO/час могли бы не искажать процедуру и исключить одну передачу.
На мой взгляд правильнее так было бы:
c.) Bouvet answers with: KL7YL 3YØZ R-02 Иначе будет 10000% обратный эффект, макросы на -02 автоматом у корреспондента будут лепить R-06 и всё пошло в кавардак!
e.) Bouvet answers: KL7YL 3YØZ 73, Но в принципе вместо 73 можно и отвечать другому зовущему.
Похоже это составлял человек далёкий от ежедневной работе в цифре и о том как работает AutoSeq
Сообщение EW2A »
Американская авантюра потерпела не удачу.....
Диму RA9USU не взяли..., вот результат
https://dxnews.com/ru/3y0z/
Главная причина возвращения - проблемы с одним из двигателей судна. Если бы вышел из строя второй, то помощи там ждать неоткуда. Примерно как в космосе.
По моему скромному мнению, за это несет ответственность перевозчик и 100 процентов, что в контракте такая ситуация оговорена. Так что он обязан будет вернуть большую часть уплаченных по контракту средств. И наверняка предпочтет свозить туда экспедицию еще раз вместо выплаты, но вряд ли в этом году, лето уже на исходе.
Сообщение EU7A »
Тоже складывается впечатление, что неуспех в данном случае связан с ненадлежащей подготовкой перевозчика. Вспоминается 3Y0X - остров Петра Первого. Только на третий год команда смогла выйти в море, достичь острова, высадиться на вертолете и успешно провести экспедицию. И неуспешные первые две попытки как раз и были связаны с судном и вертолетом, пока не нашли "правильные".
Надо пожелать сил команде, они вернутся, обязательно вернутся.
73, Андрей, EU7A
Возобновили проект 3Y0I:
https://bouvetoya.org/ekspedycja-bouvet-reboot/
Если всё же доедут туда, то чаще будут держать антенны в сторону Польши, что нам только на пользу.
Сообщение EU7A »
Думаю рано говорить об этом проекте как об возобновленном. Это просто заявление, которых за последние годы звучало немало (ON4WW и кто-то из Казахстана еще) и ни один из них не реализовался, не пошел дальше объявленных намерений.
Кстати, получить лицензию на работу с о. Буве не составляет никакого труда - норвежцы их не жалеют. "Определенные" трудности возникают когда решаешь как туда добраться, высадиться, отработать, сняться, добраться до цивилизации и при этом остаться живым и здоровым.
73, Андрей, EU7A
Видео от Нодира EY8MM:
https://vimeo.com/257078692
